Message 11 of 19
Port rule to close port 80
My bt hub 2 has ports 53, 80, and 443 open. I want to close port 80. I’ve never made a port forwarding rule before. I don’t know if they are internal or external. If I create a new rule for 53, and a new rule for 443 will that automatically close port 80? Thank you in advance
Message 12 of 19
Re: Port rule to close port 80
Why are those ports open? Have you forwarded them? Are you running a web server and DNS server on a machine.
Port forwarding simply opens ports to a particular machine, you can't set a port forwarding rule to close a port. Unless there is a rule opening the ports or UPnP  opening them they will be closed.
Edit: just seen your previous posts.
You need to have serious talk with your son who is clearly to blame.
Message 13 of 19
I just thought they opened themselves when someone is using online gaming. Apparently port 80 is set to open automatically as bts default port but I read that port 443 is a secured alternative. I didn’t know the port forwarding rules in my router log had been manually added by a person. Apparently to play multiplayer games on ps5 with friends you have to have ports open dependent on the game. My son now has no phone or laptop just the console with a child profile so shouldn’t be able to configure anything? I just need someone to tell me what I should set on the router - I’m the only person with the WiFi and admin passwords
Message 14 of 19
Port 80 is the Http port, port 443 is Https to access a web server and port 53 is DNS.
How are you discovering the ports are open?
With UPnP enabled, ports are opened and closed as required automatically.
You can either disable UPnP and prevent him playing multiplayer games or leave it enabled and allow the games to open the required port.
Message 15 of 19
You may find that even with UPNP disabled that games still work, I dont have it enabled and FC25, CS2, GTA and Tony Hawk all work without an issue.
Probably best to switch it off in most circumstances and then if a game doesnt work just look up what ports it needs open and then just open those alone pointing to the relevant internal IP address. I would delete any manual entries to start with, that table you posted looks like nearly all external ports are open pointing to one internal point and IP....although I could be misinterpreting what that table is illustrating.
EE900 | Nokia ONT | Ubiquiti ER-X | EETV Box Pro (IP Mode) | Unifi CK2 | 6x Unifi U6+ | 4x Unifi SAK Ultra
Message 16 of 19
Not sure what's going on here, I suspect he is hosting a game so this requires ports to be open. But ports 80 and 443 suggest he is running a web server. Port 53 is normally used for DNS so not sure what that is all about.
Message 17 of 19
Re: Replacement Router Hacked Remote Host
hey, really sorry you're dealing with all that — sounds overwhelming, especially if you’re not super into tech stuff. honestly, even for people who are, this would be a lot to sort through.
first off, you’re not alone in this — things can get messy fast when devices get compromised, and even more so when you’ve got someone in the house who used to mess around with hacking tools. sounds like your son might’ve had good intentions at first but things got out of hand.
a few things helped when i went through something similar:
i reset everything from scratch but made sure to do it in the right order: changed all important passwords first on a trusted device/network (not your home WiFi).
called BT and asked them to fully reset the network access and any remote management options on their end.
disabled UPnP and remote access on the router completely — these can open doors people don’t realize are there.
i kept only essential devices on the network for a while. phones, laptops — just the basics.
also — don’t feel bad for messing around in the settings. most of us do that when we’re trying to take control back. if you’re unsure, BT can walk you through locking down the router settings again.
you can get your digital life back — might take a little patience, but you’re already doing the right thing by asking questions and not ignoring it. funny enough, i had a similar issue once while setting up some online learning stuff at schoologylausd.com — thought it was a WiFi bug at first but turned out to be deeper network config stuff.
happy to walk you through anything if you want — just reply back.
Message 18 of 19
totally hear you — that sounds beyond stressful,
Message 19 of 19
This thread is over six months old so hopefully the problem has been sorted by now.
