Message 1 of 4
Ring delay doesn’t change
Hello! We have changed the handset setting “ring delay” up to the maximum 10 but the answerphone still answers at 5 rings.
anything we can do?
3 REPLIES 3
Message 2 of 4
Re: Ring delay doesn’t change
Hi @chuckychuckerson, welcome to the forum, and thanks for posting.
Firstly can you confirm if you are on a copper telephone line or the new Digital Voice with the phone service provided through your broadband?
If you ring your phone from another phone, ie a mobile, does the phone start ringing around the same time on the answerphone as you hear it in the earpiece?
cheers
John
Message 3 of 4
Hello!
maybe half a ring delay between mobile and handset, definitely not 5 rings difference.
changing the setting appears to have no effect whatsoever.
phone service is not through BT. Would that make a difference? Just the handset is BT.
Message 4 of 4
This is a community forum for BT RETAIL customers  as you are not a BT customer then you should contact your ISP for help  they will have a community forum just like this one
