Message 11 of 16
Re: Security
As you are not a BT customer there is nothing BT can do to help you. It sounds like someone has made a mistake and entered your phone number instead of their own
Tags (1)
Message 12 of 16
Re: Security
If your number has been spoofed or somehow taken over for criminal activity, then BT's Nuisance Call Bureau might be able to investigate
https://www.bt.com/help/security/how-can-i-stop-nuisance-or-scam-calls-
Tags (1)
Message 13 of 16
Re: Security
There is nothing to suggest that they are using your name, address, bank account or anything else related to you. So somebody has entered the wrong number when filling out a form.
Contact the companies that have send the messages to you about the deliveries and advise them. Other than that there is no point in doing anything else until and if you can establish that a crime has or is being committed.
Tags (1)
Message 14 of 16
Re: Security
The real issue is if you’re the one being billed for the items.  If so then you need to contact your bank/credit card company pronto and have them blocked.
Tags (1)
Message 15 of 16
Re: Security
@gg30340 Exactly that!
Tags (1)
Message 16 of 16
Re: Security
By the way, it's not pointless to report these things to Action Fraud.  If nothing else it provides proof that you've contacted the police about the fraud, which makes things so much easier if debt collectors get involved!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
Tags (1)
