Message 1 of 3
Using mobile as a router
Anyone know if there is a way I can use my mobile for a couple of hours to connect to my work laptop for a couple of hours while away from home.
I'm in a van, so would save me having to seek out a cafe to make a few work calls 🙂
2 REPLIES 2
Message 2 of 3
Re: Using mobile as a router
Hi
Yes, assuming the data tariff for your mobile permits it that there is a standard process known as a Personal Hotspot which allows your laptop to connect to the mobile using WiFi.
From memory:
If you have an iphone then with your phone's wifi turned on go into
Settings
Mobile Data (on)
Personal Hotspot (on)
Allow others to join (on)
Set a password
You should then be able to see your phone name in the laptop wifi.
Hope that helps.
Message 3 of 3
Thanks, will give it a go 🙂
