Message 1 of 5
how do I thank the line fault repair team.
I wanted to thank the fault repair team that came to fix the problem with my land line fault Reference number VOL053-XXXXXX.
They were professionalism personified. Respected my property were courteous and efficient. They explained what the problem was and how it would be resolved. Ten out of ten a credit to your business.
4 REPLIES 4
Message 2 of 5
Re: how do I thank the line fault repair team.
@osborner
Please edit out your fault reference and email address, as its personal information and this is a public forum.
Use this form to provide feedback https://www.openreach.com/help-and-support/thank-an-engineer-form
Message 3 of 5
Thank you so much @osborner.
If you would like to thank an engineer that turned up from Openreach, please, see the link that @Keith_Beddoe sent in his reply.
I've removed your private information for you.
DanielS
Message 4 of 5
thanks for the advice
Message 5 of 5
thanks
