Message 11 of 26
Re: xatreon.com
Didn't know I was. Anyway, can you help with the problem, or not?
Message 12 of 26
Re: xatreon.com
Did you read any of the replies!
Message 13 of 26
Re: xatreon.com
Clearly not
Message 14 of 26
Re: xatreon.com
I apologise most sincerely for my ignorance. I would be very grateful for any positive input regarding this matter. I hoped for helpful guidance in this forum, and I'm sorry to be such a nuisance.
Message 15 of 26
Re: xatreon.com
While it is not a BT matter you have already been given helpful advice in this thread if you care to follow it.
Message 16 of 26
Re: xatreon.com
You have been given at least 4 pieces of advice which you have so far ignored.
Message 17 of 26
Re: xatreon.com
Ouch! I withdraw, embarrassed, chastened, cowed and overawed by your massive powers. Reveal yourselves, supreme beings, that I may bow before you...
Message 18 of 26
Re: xatreon.com
Goodbye.
Message 19 of 26
Re: xatreon.com
Good way to get help.
Message 20 of 26
Re: xatreon.com
Using Windows if you click on the windows "start" icon you can then type "control panel".  From there if you select "Programs" you'll be presented with a list of installed programs.  You can click on the "Installed On" column header to order by most recently installed.  if you are lucky, the program may show in there!
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
