Message 1 of 3
2 factor authentication login is broken
After 20 years of using bt email they now decree that I am too stupid to use a password only login and have to do 2 factor authentication. And their brilliant programmers cannot produce a login procedure that works in the Firefox web browser on a Mac. It does however work in the Edge browser in Windows 10. At least, the email login worked, but the bt account login failed when I tested yesterday.
I'm giving up with bt, they are hopeless.
2 REPLIES 2
Message 2 of 3
Re: 2 factor authentication login is broken
No idea where you get notion that 2FA is compulsory on BT email. It isn't.
Maybe it's Apple paranoia.
Message 3 of 3
So is your post just a moan or are you looking for some assistance?
