Message 581 of 952
Re: BT Webmail Feedback
I do not have forwarding set up for Gmail.
I do have forwarding set up for old TalkTalk and VirginMedia accounts. Those emails are forwarded into my BT Email account.
I am no longer a BT Broadband Customer and I do not pay for Premium Email.
I last had BT Broadband about two years ago but I have continued to use BT Email as my main email.
When BT email changed recently I had and still have many problems which I am working around until the fixes are in place. My problem with not being able to send emails only started on Thursday 29th February into Friday 1st March. I believe I am receiving emails ok.
Message 582 of 952
In that case, you will have been downgraded to Basic Mail which can only be used by webmail, not by clients such as Thunderbird.
Message 583 of 952
Should I be reporting this as a fault?
And who do I report it too? BT or my current Broadband provider?
Message 584 of 952
I do use Webmail. Although the problem is happening on both Webmail and Thunderbird.
As the problem was happening to every email I have sent since 29/2 1/3 on Webmail I thought I would try Thunderbird to see if it worked on there but it didn't.
I do not use Thunderbird often as I prefer to have my Email on my Web Browser.
Message 585 of 952
Rading a few of others' postings, this error and messed up formatting was probably caused due to saving the email in drafts before sending it, rather than using the reply to all facility.
But a question remains have BT acknowledged and published a list of the bugs which their "upgrade" has caused?
How is progress monitored?
Why don't they roll back until they sort themselves out rather than have an embarassing community thread of 59 pages of problems?
Message 586 of 952
The new email system is absolutely appalling, messages come in and its hopeless trying to read them as part of a word is on one line and the other part of the word is on another line - This is a rem
inder that you have an engi
eer calling t
day
Then when you try to type an email, after a few words you suddenly look at the email and find that after a few words the rest of it goes to the top of the email  and in front of the header title so you get -
ivering the shedtodayHi Jim
Will you be deliv
BT needs to get their act together and sort these problems out
Message 587 of 952
@chrisgore
Emails replies will go to Drafts irrespective of whether you Reply/Reply All/Forward to an email. This is how emails are saved in case of a crash or for you to return later to resume the reply. It's the same in Webmail or an email client such as Outlook
Message 588 of 952
thanks Neil
Not sure how that explains some of my emails are now being received looking like this:
doesn=E2=80=99t want, once we supply them with a final copy of th=
e=20
Or including this:
I look forward to hearing from you.
=C2=A0
Kind regards
=C2=A0
Chris
=C2=A0
=C2=A0
=C2=A0
When I originally posted this on this community site I had thought that the problem was due to be having used the reply to all facility, but reading other contributions, I suspect it was because the way that BT was now saving emails.  Other posters seemed to be suggesting the same.
The fact remains that people have complained that emails are being received corrupted after BT upgraded the email - an upgrade which has over 50 pages of comments and complaints and not a single response, as far as I can see from a communications company saying something along the lines of: we have identified these xx bugs and will be updataing you on progress by a given date.
or to acknowedge that the upgrade was a mess so that they will roll it back until they sort it out.
Message 589 of 952
I have begun adding a paragraph to the beginning of my emails informing recipients that the bizarre formatting of large and small fonts etc is not me going doolally!
Message 590 of 952
good idea - could add to signature with apology for BT incompetence
