Message 671 of 952
Re: BT Webmail Feedback
Sadly yes!
Message 672 of 952
Re: Are you unhappy with the new version of email on PC or is it just me?
Is anyone on this thread on a 'rolling contract'?
I'm on a rolling contract, but it's due for renewal in 'a few' days. In trying to discover the exact date, I uncovered yet another bug - that'll be about #40, I reckon.
At the top of my webmail page, there's a navigation banner:
EVERY SINGLE ONE of those links goes to a webmail page - INCLUDING MyBT!
It opens properly (with a separate login) from this 'community' page.
Edit (I've found that now!) - after several minutes of searching, I still can't find a contract expiry date anywhere.
Message 673 of 952
The Mail, Contacts, Calendar and Tasks buttons are meant to take you to a web page of the webmail showing these named pages with the a list of your contacts, a calendar and task that you have set up in your calendar.
The MyBT button should take you to the MyBT log on page.
The Help button should take you to the email Help pages.
I have checked on three BTMail accounts using Edge, Firefox and Chrome and that is what happens on all these browsers so it would not appear to be a universal problem.
When you say "webmail" page what webmail page is it?
Message 674 of 952
@RichardHaselgrove
To find your contract end date log onto your MyBT and go to "Track Orders" then "Order Summary" or on your Bill.
Find your contract end date | BT Help
Message 675 of 952
Thanks - but I haven't found those words on any of the pages you mention. I finally got the info from:
Message 676 of 952
You will see all the areas of MyBT if you hover your mouse over the "MyBT" button in the menu bar. The main title in which you will find what I posted is the heading "Orders and Faults".
Message 677 of 952
They are all variants of "https://email.bt.com/mail/index-rui.jsp?v=ci-MX_3.2.1#/mail".
The first four have final words matching the matching link - mail, contacts, calendar, tasks. The final two have nothing after the final backslash.
Using Chrome under Windows 7 x64 on this machine - I can check Windows 11 and Linux Mint, if you want.
Edit - yes, OK,  hovering over MyBT gets you to the order history for the last renewal - placed 16 March 2022, actioned 17 March 2022. But it's a bit obscure, and doesn't actually state either the duration or the expiry date.
Message 678 of 952
I would guess the change is either to save money or because they want people to move away from the product.
If they do bring out a patch or correction quickly I might amend that view.
Assuming the software was tested who signed it off as a good idea and why? - Given the strong negative feedback on here I cant see how it was released other than based on my first two points. It would be interesting to know what testing was done and what the customer benifits were supposed to be (again considering the feedback on here). As long term customer who feels very let down I think that is a valid question.
Message 679 of 952
@RichardHaselgrove
Did you click on Order Summary as I mentioned.
Message 680 of 952
Yes I did - that's where I saw the 2022 dates.
