Message 1 of 7
BT Webmail login on Chrome
For a couple of weeks I've been having problems logging in to Webmail on Chrome - version 157.0.8103.79.  No problem using Firefox 160.0 or the BT Webmail app on my Samsung Galaxy A12.
Going through bt.com - MyBT - clicking Email top right and entering my login info as normal, I then get this login screen which keeps looping round and never letting me enter anything
Any thoughts anyone?  Or should I make Firefox my default browser?
6 REPLIES 6
Message 2 of 7
Re: BT Webmail login on Chrome
Hi @picketywitch
Our Email Team isn't aware of any reasons why you'd be facing this trouble when using Chrome.
I'd suggest to continue using Firefox or the BT Email app.
Linzi
Message 3 of 7
I'm having exactly the same issue today. It's happened before and someone posted a successful solution on here which I will search for.
Found it here:
31-10-2025 16h18
Re: Login problem
@Cliverh
Press F12, there's a top menu in the developer window (elements/console/sources/network/ etc). You may need to scroll right on the menu bar (or expand the size of the developer window to see all options).
Select "Application". You should then see a menu down the left side of the pain which includes "Storage"
Click on "Storage". There is then an option in the developer pane to "clear site data" along with a check box to "include 3rd party cookies".
I just tried it again and I was able to log-in with no issues.
Message 4 of 7
At what point do I press F12?  On my laptop F12 toggles flight mode on or off.  It doesn't offer the menu suggested in the solution
Message 5 of 7
Press F12 when the  bt log-in page is open.
Message 6 of 7
Basically just clear your cookies and cache.
Message 7 of 7
Wow, thank you that's worked!  Didn't have to use the F12 button though......
