Message 1 of 5
Can't connect to webmail service
Hi
I can't connect to the webmail server unless I have my VPN running.  Without the VPN all I get is a web error page, can't find server, check DNS etc.  With the VPN running everything works fine.  This problem is with different browsers and I 've tried different devices.  I can get email through a mail client with no problem.  I've restarted my router.
I'm assuming BT is blocking my router ip address.
Any thoughts?
4 REPLIES 4
Message 2 of 5
Re: Can't connect to webmail service
Are you a BT Broadband customer or are you paying for your email through a BT Premium Email account?
Are you using a BTMail email account?
Are you using a BT connection or are you using another network?
Are you in the UK.
Are you using a BT hub?
If you are using a BT hub have you tried a factory reset of the BT hub by pressing a pin into the recess button on the rear for about 20 seconds?
What device are you using to access your email.
If you are a Talk Talk customer TalkTalk DNS for bt.com has been down for days. TalkTalk users can't access any BT services, causing so many calls and complaints being raised with BT.
There's a 3 day old thread on the TalkTalk forums with no reply from them so far.
Home - TalkTalk Help & Support
Message 3 of 5
gg30340
Thank you for the reply; that's a lot of questions.
I'm a premium email account holder, nearly moved back to BT but TalkTalk coaxed me back again.
So yes, I'm on TalkTalk.
In terms of what devices I'm using:  Mac Mini/ Dell Laptop. and an iPad.  None of which can access webmail, all of which can get mail via a client Thunderbird/Mail/Gmail (android).  I can access webmail on all of them if I engage a VPN.
So I guess the problem lies with TalkTalk rather than BT
Message 4 of 5
OK, so....
...I went onto my TalkTalk dashboard on the KidsSafe setting I added BT.com as a site to be allowed to connect to and hey presto it worked.
I then switched Kidsafe off and then back on (this clears the allowed sites), and it still worked, ( I was expecting it not to) .  It seems that somehow this process has kickstarted my access to BT again.
Thank you for the hint as to where the problem lies
Message 5 of 5
There was reports in press of TT customers  having problems accessing BT email addresses
