Message 1 of 4
Emails.
My bt email app keeps.wanting me to.go through the long.prrocess of logging in and waiting for.passcode etc
Can anyone help.
3 REPLIES 3
Message 2 of 4
Re: Emails.
That is because of two factor authenticaion that is now in force. It can not be turned off.
Message 3 of 4
Re: Email
I have to re log into app everytime I want to read emails it is getting me down and will soon stop using bt
Message 4 of 4
Re: Email
@Alison1004
stop using your BT mail app and use a third party app like thunderbird or bluemail and you won't get the 2FA problem.  BT mail is supposed to 'learn' if you are accessing with same device and eventually stop the 2FA request.  I use a third party so can't check if that actually happens
