Message 1 of 2
Exporting BT Business Mailboxes
Hi,
I'm in the process of moving a clients website from BT to Siteground, including mailboxes.
How can I export mailbox contents to be imported into the new hosting? Sync seems to fail with any desktop app and webmail has no the Export function removed.
I'm sure I'll have to try and contact BT support for other issues but this is the first time I've come across mailboxes that seem to be locked to the host (or MS in this instance).
Thanks,
Paul.
1 REPLY 1
Message 2 of 2
Re: Exporting BT Business Mailboxes
this forum is for residential customers with customer helping customer and you post does not go to BT
try the business forum  https://business.forums.bt.com/
