Message 11 of 14
Re: New webmail: Automatic ticking of emails selected - how do you turn this off?
Evidently I posted to the wrong person. Many apologies
Message 12 of 14
No problem, thanks for your help with this issue.
Message 13 of 14
I have had this problem ever since the new Webmail came on stream.  I don't use preview pane.  Was hoping your solution would work for me but it doesn't as I don't have Settings visible anywhere!
Message 14 of 14
Just replied couldn't find Settings at top left of screen to turn this off, but have now found Settings when I click on my user name at the top RIGHT of the screen and yes, there is an item to turn off after delete.  Fixed now that goodness!
