Message 1 of 3
Webmail only holds emails for 2 days
HI,
Since BT has changed the layout and look of it's webmail, when accessing it through a browser (have tried both Edge and Chrome), I can only see emails relating to the last 2 days.
Is there a setting that I can change to restore the full view.
I use outlook on a IPhone for the same email account and that works as expected.
Any assistance greatly appreciated.
2 REPLIES 2
Message 2 of 3
Re: Webmail only holds emails for 2 days
Make sure you don't have "Conversation" view selected in the "View" settings on the right hand side. You can toggle it on/off by a single click.
Message 3 of 3
That fixed it, no idea why it changed!!
Thanks very much for the help
