Message 1 of 3
BT remote code 4985 doesnt work for Sony Bravia TV 2015 model
BT remote code 4985 doesnt work for Sony Bravia TV 2015 model. It does switch off the tv but does not switch it back on or control volume or any other functions.
Is there another code?
2 REPLIES 2
Message 2 of 3
Re: BT remote code 4985 doesnt work for Sony Bravia TV 2015 model
Hi @dazzler1 Thanks for posting, I'm sorry there are no other codes to try for Sony TV's.  Are you following these steps, see step 5 as you may need to press OK instead?
  1. Hold down both the TV and TV AV buttons for at least three seconds until the blue light flashes three times
  2. Release the buttons and enter the four-digit code for your brand of TV. If the code works, the blue light will flash another three times
  3. Point your remote at your TV and hold the TV button until your TV turns off. This can take a while as your remote will try different codes for your brand of TV (the blue light will blink briefly each time it tries a new code)
  4. When your TV turns off, release the button, then test your remote by pressing TV to turn your TV back on, then Vol +, Vol - and TV AV
  5. Some TV’s will not respond to the TV button press to turn your TV back on. If you see a red light on your TV then you could try pressing OK or go back to step 4
  6. If everything's okay, press OK to confirm. The blue light will flash again and your remote will be programmed for your TV
  7. If it didn't work, start again from Step 4 and the remote control will continue to search from where you left off (or you may want to restart from Step 1 if you're not sure you entered the right code)
To reset your remote, hold down the AD, DELETE SUB and BT PLAYER buttons at the same time, until the blue light flashes three times.
Neil
Message 3 of 3
Yes tried that but the 4985 code doesn't work
