Message 1 of 2
TV remote
I have recently swapped from Sky to BT TV, I find the remote very user unfriendly is there a version for people with fat fingers?
Thanks 👍
1 REPLY 1
Message 2 of 2
Re: TV remote
This question has been asked in the past on the Youview forum yet I'm not aware of any answer either from Youview or BT.
There are big button learning remote controls available on sites like Amazon for less than £20 or you could take a gamble on a large button One For All (OFA) remote control which can do both, learn from the original control or (as I found out) find a code that works using the Search method (mines not big button though)
