Message 1 of 2
tv box to the router
Hi ,
I have my box connected via the bt socket adapters and it works fine. I am trying to change it to a standard Ethernet cable but when I do I get no broadband connection.
Can anyone help?
A great collection of porn for asianpussy lovers
https://asianpornpussy.xxx/
1 REPLY 1
Message 2 of 2
Re: tv box to the router
Assume you have the ethernet cable plugged into yellow socket on router and ethernet socket on rear of vision box?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
