Message 1 of 9
Digital Voice
I have been moved o DV and told I will be charged at 22.? per minute for all calls. I asked if the 0800 number were free and told NO . I asked if I would then have to pay to speak to BT and told as all calls charged ................ Is this right ? I cannot find any information on free calls.
8 REPLIES 8
Message 2 of 9
Re: Digital Voice
you must have selected PAYG and not a call package but call to 0800 and 150 or 03301234150 to BT are free
Message 3 of 9
Re: Digital Voice
It's all here:  Call costs guide from Ofcom.
Message 4 of 9
Re: Digital Voice
Digital Voice charges are exactly the same as the previous analogue charges.
Message 5 of 9
Re: Digital Voice
Thank you. So 0800 numbers are free as analogue and the BT adviser was wrong. Thank goodness for that
Message 6 of 9
Re: Digital Voice
Yes.
Message 7 of 9
Re: Digital Voice
Correct, I really do despair about the training BT advisors get.
Message 8 of 9
Re: Digital Voice
Of course they are "Guides" now so by definition they can also misdirect you or lead you astray.....
Message 9 of 9
Re: Digital Voice
