Message 1 of 7
Outgoing Calls
Any Ideas? Why does my phone make a call once a month to an ADT account that I no longer have even when ive blocked the no?
So i'me being charged for this everyt month
6 REPLIES 6
Message 2 of 7
Re: Outgoing Calls
Presumably that's the alarm company ADT? In which case it's the alarm dialling, not your phone. You can't block outgoing numbers, so you need to disconnect the alarm if you want to stop it.
Message 3 of 7
Re: Outgoing Calls
@chrissy1
Welcome to this user forum for BT Retail phone and broadband customers.
Your phone cannot make calls, but your alarm unit can. If you are no longer using ADT, then disconnect the alarm unit from your phone line.
Message 4 of 7
Re: Outgoing Calls
A lot of intruder alarm systems will every so often "phone home" they will do a handshake with the alarm company to check a number of things. 1. That a phone line is connected. There may be an update of software on your alarm panel. 2. The system will do a sanity check to ensure there are no problems with the alarm panel. 3 any system logs will be downloaded.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 5 of 7
Re: Outgoing Calls
When you do cut power to the alarm system/switch it off as we did a few years ago for that system, just be aware that many of them have a back up battery., At 3am about 3 or 4 days later we were all woken in the middle of the night by screeching alarm sounds on the alarm I thought was switched off and then I realised this must have been when its back up battery expired.
Message 6 of 7
Re: Outgoing Calls
Thank you for your help
Message 7 of 7
Re: Outgoing Calls
Tags (1)
