Message 1 of 3
EE TV Web Player error
I've just downloaded the EE Web Player for Windows (after a message on the old BT web player program said it's now been replaced by the EE program).
So now if I go here https://player.ee.co.uk/#/livetv/watchlive when select some live sport it opens the EE program but I get this error:
You've reached your device limit You have reached the limit on the number of devices you have registered for playback. (WP933)
Apart from my BT Youview box I only have the EE TV android app for watching TNT sport so I don't know why it would think I'm registered on too many devices. Is there a list of my devices somewhere I can check/edit or some other solution please.
2 REPLIES 2
Message 2 of 3
Re: EE TV Web Player error
Hi @fiddlesticks01, check out: Managing your device on the EE TV App | BT Help and you should find the devices already registered.
Cheers
John
Message 3 of 3
Hi John, cheers for the quick reply - it's sorted the issue.  Many thanks.
