Message 11 of 14
Connection is awful on ps4 since jan 24th
something happend from jan 24th 2026
online games are running very badly
its like im using a hotspot off of old mobile phone thats how bad it is
its horrible
im using an ethernet cable something really bad is happening here
Message 12 of 14
Re: BT HUB 6 Playstation 4
@Sml5678 Do you notice any of these issues when using your other devices for similar services like gaming on your PC?
If our technical team have ran all the checks on your connection they can for now, the best next steps would be ruling out that it is just a PS4 issue by comparing other devices on the same network. Have you been able to run a ping test or see it in game to confirm it is what is causing the issue?
Alex
Message 13 of 14
I only play online games on the PS4 but its happening with more than 1 game
I can't remember the exact date it started but I did plug in the new BT Hub Smart 6
I don't know if its the HUB causing this or it's something else
Even people playing against me have told me my Internet is very very bad
this type of thing has never happend to me I've been with BT for over 15 years.
Is there a way to check the ping on the PS4 and on a laptop?
Message 14 of 14
@Sml5678 Have you switched back to the old hub to test that?
Some games allow you to show the ping as an overlay when playing so depends on the games you play you would have to google, that would be the best test to see if its a ping issue.
 Outside of that you can just use the browser app on the PS4 to connect to a speed test like Ookla which will show your ping or any ping test if you google. You can do the same on your laptop.
Alex
