Hi, I renewed my contract at the start of the month and it said that the line would be regraded but nothing seems to have happened (It has rebooted since). It seems to be stuck at 35Mbps but it should be capable of a bit more, here's the stats from my HH2 (It has the latest firmware, Dec 2025):
Maximum data rate:6.512 Mbps / 43.321 Mbps
Full Fibre (FTTP) Mode:Off
Noise margin:5.9 / 9.9
Line attenuation:11.1 / 23.0
Signal attenuation:11.1 / 29.3
That downstream noise margin is high at 9.9 (For most lines 6 is normal). Only you would know if that is normal for that line, but it suggests a lot of noise on the line.
I’d run a quiet line test, (17070, option 2), and see if you can hear anything. It should be silent. If not phone it in as a phone fault, (not a broadband fault).
have you had previous problems with your internet connection dropping or have you been resetting the hub often in hope that the speed will improve?
I looks like the DLM as your connection ibn a banded profile due to line problems
Hi, thanks for the reply, it's a digital only line and we don't have a landline now.
Thanks for the reply, yes we did a while back - around the time we last re-contracted. We had some old aluminium cable between us and the green cabinet which caused a lot of problems. Eventually some of it got replaced and eventually after a lot of problems I got connected to a pair on that cable which has been fine since.
I personally think it's been capped, I never reboot the hub - it just does the usual reboot every 14 days and is very stable. I did try having a conversation a long while back but they couldn't help (I don't think they understood!) I gave up on it and it was only recently when I re-contracted that the mention of a regrade reminded me! It doesn't seem like we're getting fibre any time soon so any extra speed helps.
