Message 1 of 4
Removing BT Box
I have 3 telephone sockets (one BT, one virgin and one standard by builder) I also have fibre connection for BT and one for Virgin. I’m trying to tidy up my wall and want to remove the BT one.
Am I right in thinking that the attached is old copper and I can remove without interrupting my fibre?
the loose box has been taken off but leads into the other box
unfortunately image is too big so will need to rethink!
3 REPLIES 3
Message 2 of 4
Re: Removing BT Box
No.... you cannot touch it.
It is the property of openreach. You will need to contact your ISP(in your case BT) to have it removed together with the cable to the outside, if fed overhead. There may be a charge for this.
Message 3 of 4
Re: Removing BT Box
Ooops. Already removed it. Certainly wouldn’t pay to have it removed.
Message 4 of 4
Re: Removing BT Box
Just remove it Openreach could not care less or even know if it is removed.
