Message 21 of 23
Re: Router identification
Minimum speed guarantees are nothing more than administrative, a point at which you can’t complain about speed , no one physically limits downloads to the MSG , the line delivers what it is capable of delivering irrespective of the MSG upto the speed profile you pay for , the Openreach service and the provider MSG are not  linked in any real way as far as limiting the speed but what Openreach deliver is the basis for the MSG  ….., the advertising authority and Ofcom requires the customer to be given this figure , unfortunately as is the way with unintended consequences, if the MSG is based on a faulty lines actual performance so artificially lower than if the line is fault free , then getting a speed issue resolved is problematic if it’s still delivering above the MSG .
The only ‘locking’ is if Openreach apply a banded profile to stop instability, normally FTTC uses dynamic bandwidth allocation, if a line gets worse , the speed reduces to keep it stable , if the line conditions improve (because a fault is removed) it gets better , but if the line were up one minute and down the next , DLM may effectively set the line semi permanently at a speed that’s stable , this is called banding and should release after a period if stability, but occasionally it needs to be requested to have it removed and to let the line retrain to it’s optimal speed.
Have you done as requested, router in the master socket test port and recheck, and run a line test yourself from your online account ?
Message 22 of 23
@caledonia
as @iniltous  mentioned I think you are in a banded profile with 35mb down and noise margin at 9db.  Have you been having drops in connection or more likely resets of the hub in hope to improve your connection speed.   resets will make it worse not better.  if you maintain a stable connection the noise margin should reduce to normal 6db giving increase in speed.  If line is good then noise margin may drop to 3db giving another speed increase
Message 23 of 23
Before i got new router it was dropping 5-7 times a night
only put it in yesterday so will keep an eye on drops
