Message 1 of 12
how can i tell witch type bt broadband service we using copper to copper or FTTC
how can i tell witch type bt broadband service we using copper to copper or FTTC  and  line rental prices   speed  16 mbps
11 REPLIES 11
Anonymous
Not applicable
Message 2 of 12
Re: how can i tell witch type bt broadband service we using copper to copper or FTTC
Anonymous
Not applicable
Message 3 of 12
Im guessing you might not have fttp with a speed of 16mbps .
Or you could just check your BT bill
Message 4 of 12
Anonymous
Not applicable
Message 5 of 12
sign account on the webpage or use live chat via the hep page
Message 6 of 12
No as its not available with bt in Wareham Dorset to date   only copper to copper  or  FTTC or as its none now SoGEA
Message 7 of 12
FTTC products have ‘fibre’ in their name , BT Fibre Essential, Fibre 1 , Fibre 2 (40Mb , 55Mb , 80Mb ) BT  ADSL products, usually advertised as having an average speed of 17Mb don’t have Fibre in their name , so BT Unlimited Broadband or something like that .
As  ADSL is no cheaper than FTTC  , unless there is a reason why FTTC isn’t available (no cabinet or no spare connections in the cabinet) or performance is worse on FTTC than ADSL (this can be the case on very long lines from the cabinet )there is no reason to be on ADSL .
If you want a more technical way to tell , look at your router modulation type,
G992.3 is ADSL2
Message 8 of 12
BT bill is not ionized to that point just outgoing call cost and line rental cost !!!!!!!*********
Anonymous
Not applicable
Message 9 of 12
 While I have no knowledge of atoms or molecules I can confirm that your BT bill will clearly state if you have a Full Fibre (FTTP) package.
Message 10 of 12
If you logon to your  BT Hub   management pages and click on "Broadband Status" it will show what type of connection you have. It will either be ADSL  copper broadband, VDSL Fibre to the Cabinet or FTTP Fibre to the Premises.
You are most likely on VDSL FTTC.
