Message 1 of 7
0800 328 9393
Does anyone know who this number is? its rang me twice in 3 months and when I ring it back it says "its BT we tried to contact you don't worry we will try again" I've been successful with a trainee engineer application with Openreach. Does anyone know if this is the recruitment team? seems bizarre to have a number that doesn't leave any message and you can't ring back. And they don't bother trying to ring you back for another couple of months?
6 REPLIES 6
Message 2 of 7
Re: 0800 328 9393
@IamJohno
Please post on this forum http://forums.thinkbroadband.com/job.html
This BT Retail forum has nothing to do with Openreach.
Message 3 of 7
Re: 0800 328 9393
Hi.
The number is the generic BT number presented when a BT staff member calls from their internal desk number.
Message 4 of 7
Re: 0800 328 9393
Its not likely to be Openreach as they are a separate company now, so its probably to do with an account or sales call.
There is no mention of that number on the jobs forum that I linked to.
Message 5 of 7
Re: 0800 328 9393
Confirmed that number is also  sent if an openreach employee makes an outgoing call.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 6 of 7
Re: 0800 328 9393
any reason why I cant ring this number back? its meant to be giving me a start date at openreach but they don't leave a voicemail or email ..
Message 7 of 7
Re: 0800 328 9393
It's simply a delivery number set by BT on pretty much all their internal extensions when they dial out - so not one specific person.
