Message 21 of 27
Re: 900mpbs new setup dissapointed
I'd go with the ASUS but that is just preference.
Message 22 of 27
Yeah heading that way myself but not many places have stock, must be popular plus Covid problems i expect.
Message 23 of 27
Try Scan computers less than £220  (inc delivery) and you can get it delivered tomorrow if ordered within the next hour.
Can't give you the direct link on the forum.
Sorry that's the RT-AC88U
The AX88U is due in on 22nd March.
Message 24 of 27
That Asus offer support from Merlins branch of code and a few other bits and bobs but the chipset is one of the original ones.
if you search smallnetbuilders forum you can find lots of info on Asus and their different ax routers as well as other manufacturers.
Message 25 of 27
I would if I could afford it, go for a Draytek 2927 (router only) with a wifi6 mesh.
Message 26 of 27
Went for the tp link archer ax6000, its 230 and 70 quid cheaper than the asus, not sure the asus is 70 quid better, i will update the post whennits arrived and setup
Message 27 of 27
I paid £156.99 from Amazon for the ASUS RT AC86U.
I use that router with the Merlin custom firmware.
It connects direct to my ONT and connection is brilliant... can recommend this router.
