Message 11 of 12
Re: Access Controls
Hi @Keith_Beddoe no other suggestions, the reset is a good place to start.
Message 12 of 12
Re: Access Controls
@NeilO @Keith_Beddoe
Thank you both for your suggestions. I will give this a try and report back if it helps the issue.
Maybe BT haven’t heard of the term “if it’s not broken, don’t fix it” ha ha
