Message 1 of 6
Admin timeout issues
Hi, I have just come back to BT. New smart hub 2 etc. Alrighty, it now drops out far too often. The engineers came out, squared it all away tested, new master socket and appeared fine. As I waved them off the drive I glance over my shoulder and see the internet drop out. Doh. I have 3 ethernets, 1 to a switch, and them out to a TV, a powered ethernet to a hub and a third ethernet to a garden Room to a older bt hub and x box. I have looked at logs etc not clear. Any advice would.be great. Cheers Andy
5 REPLIES 5
Message 2 of 6
Re: Admin timeout issues
Have you turned off smart setup in hub Manager?
Have you tried without  ethernet connected to see if that stops drops in connection. If that helps then reconnect 1 ethernet connectionat a time to see if still stable
Message 3 of 6
Re: Admin timeAout issues
Hi, thanks yep I have turned smart set up off already, and it’s been we’re up etc. I’ll try unplugging , although I had treated the tv wireless, good signal etc but still dropped out. Even my WiFi’s phone drops and the iPad I am using now, maybe for 15 seconds or so. I’ll unplug tomoz and work it through. I’ll let you know. Thanks andy
Message 4 of 6
Hi @Andybarnes180,
Thank you for posting. How often does the connection drop out? When this happens does the hub restart?
Removing the ethernet connections as suggested by @imjolly will help to eliminate anything on your home network that could be causing the disconnections. I know from passed experience that switches can sometime cause the disconnection so I would probably look to eliminate that first.
Paddy
Message 5 of 6
05, 04 Sep.
ARP [add] br0(wl1) 192.168.1.111 3e:87:10:24:bc:44
19:45:56, 04 Sep.
DHCP device Connected: 192.168.1.111, 3e:87:10:24:bc:44, Victoria-s-Galaxy-A21s
19:45:56, 04 Sep.
LAN [ADD] ARP 192.168.1.111 with 3e:87:10:24:bc:44 from br0(
19:45:56, 04 Sep.
5G Client disassociate from 3e:87:10:24:bc:44 (IP=192.168.1.111) RSSI=0, Rate=0Mbps
19:45:55, 04 Sep.
WHW INFO A station (Smart Hub 2)IF[2.4G](8C:19:B5:4E:B4:2F):STA(3E:87:10:24:BC:44)(Legacy Device) join WHW infrastructure
19:45:55, 04 Sep.
WHW INFO A station STA(3E:87:10:24:BC:44) leave WHW infrastructure
19:44:49, 04 Sep.
Port forwarding rule added via UPnP/TR064. Protocol: UDP, external ports: any->3074, internal ports: 3074, internal client: 192.168.1.71
19:44:48, 04 Sep.
Port forwarding rule deleted via UPnP/TR064. Protocol: UDP, external ports: any->3074, internal client: 192.168.1.71
19:40:51, 04 Sep.
19:40:51, 04 Sep.
19:40:51, 04 Sep.
ARP [add] br0(wl0) 192.168.1.111 3e:87:10:24:bc:44
19:40:21, 04 Sep.
DHCP device Disconnected: 192.168.1.111, 3e:87:10:24:bc:44, Victoria-s-Galaxy-A21s
19:40:20, 04 Sep.
LAN [DEL] ARP 192.168.1.111 with 3e:87:10:24:bc:44 from br0
19:40:16, 04 Sep.
ARP [del] br0 192.168.1.111 3e:87:10:24:bc:44
19:39:19, 04 Sep.
19:39:19, 04 Sep.
19:39:19, 04 Sep.
19:38:53, 04 Sep.
19:38:52, 04 Sep.
19:38:49, 04 Sep.
ARP [add] br0(wl1) 192.168.1.67 2a:90:f0:88:84:9a
19:38:49, 04 Sep.
ARP [del] br0 192.168.1.67 2a:90:f0:88:84:9a
19:38:48, 04 Sep.
Message 6 of 6
Hi, the flick off continues, the smart tv is now using the WiFi, some 4 m away in the roof, we are in a bungalow.
Obviously the phones are WiFi...does the tech log show anything obvious? Cheers Andy
