Message 1 of 3
Alexa Digital Voice Phone
I've just bought myself a nice new, fast WiFi 6 access point. I want to turn ogg the WiFi in the Smart Hub 2 but I'm wondering how can I connect the Digital Voice phone? it seems to only have the option to connect via WPS. Is there a way to connect the traditional way?
2 REPLIES 2
Message 2 of 3
Re: Alexa Digital Voice Phone
Just turned off the WiFi and found it still works. It must connect using one of the SSID's that you can't disable.
Message 3 of 3
@RDowson
It does not use wifi, is uses DECT. There is a DECT base station inside the Smart Hub 2.
https://en.wikipedia.org/wiki/Digital_enhanced_cordless_telecommunications
Wifi access points will not have any effect on the range of connection.
