Message 11 of 16
Re: Android Mobile
Message 12 of 16
Re: Android Mobile
Thanks but have also tried that without success.
Dan
Message 13 of 16
Re: Android Mobile
@DanMeehan Are you using a VPN on your mobile?
If it's only affecting your mobile and you're not having any issues accessing your email on any other email clients or via the website it does point to a problem with the phone.
Neil
Message 14 of 16
Re: Android Mobile
Sorry but this was a problem on my previous mobile. Having just purchased a new phone I wanted to get the issue sorted - but obviously no solution. Thanks anyway.
Message 15 of 16
Re: Android Mobile
A couple of things to try.
Go to your MyBT and check under manage email that your account type is shown as 'Standard'
If it is, stop any devices trying to access the email account, change your email password in webmail, wait at least an hour to give the servers chance to sync password change and then try setting up the account again on your mobile.
Message 16 of 16
Re: Android Mobile
Fantastic - it worked. I CANNOT explain why but when I tried to change my password it said that my 'original' did not match despite it matching the passwords automatically stored and being a particularly memorable password. Irrespective of that - thank you.
