Message 1 of 16
Appalling Hub Speed Negociation
When my VDSL connection is dropped for any reason (power or periodic hub dropout) my Smart Hub 2 can take half and hour to negotiate the connection again if left to itself. If I power-cycle it after it has made its first attempt and failed, then it usually connects more quickly. This has _always_ been an issue.
We are at about the limit for VDSL operation over the copper from the cabinet to the house (>3km). Its a fully-digital cabinet so ADSL is not available.
Some time ago, while sorting a long-latency issue, an engineer made a change that improved things, but it is always desperately slow reconnecting now. (We still sometimes get slow-latency but not always)
Any ideas?
15 REPLIES 15
Message 2 of 16
Re: Appalling Hub Speed Negociation
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 16
Product code:Smart Hub 2
Serial number:+091298+1849001036
Firmware version:v0.21.03.07094-BT
Firmware updated:Sat Oct 24 03:01:57 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:0 days,14 Hours57 Mins00 Secs
Data rate:1.137 Mbps / 4.509 Mbps
Maximum data rate:1.137 Mbps / 5.213 Mbps
Noise margin:7.5 / 4.5
Line attenuation:4.6 / 38.7
Signal attenuation:15.9 / 60.3
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:139.0 MB Uploaded  / 726.5 MB Downloaded
Message 4 of 16
Message 5 of 16
You would be better on ADSL, as its shown as available.
It comes from the exchange, so the fact that your main cabinet is linked to a fibre cabinet, has no bearing on that.
The problem is that it seems to be impossible to order an ADSL connection, if there is FTTC available, even though the connection may be worse.
It should be possible to override the order system, and allow an ADSL regrade to take place, otherwise there is nothing you can do.
You are well below the minimum USO speed, so BT should off a 4G mobile connection, provided you are in a 4G coverage area.
Message 6 of 16
Basic Speed Test
Broadband Speed Test
Executed Successfully
PING 21ms
DOWNLOAD 3.81Mbps
UPLOAD 1.06Mbps
Advance Test
Download Test
Download speed achieved during the test was 3.81 Mbps
For your connection, the acceptable range of speeds is 2.82 - 4.03 Mbps
IP Profile for your line is 4.03 Mbps
Upload Test
Upload speed achieved during the test was 1.06 Mbps
IP Profile for your line is 20 Mbps
Message 7 of 16
No copper from the cabinet to the exchange is available. Its all in use. I've asked.
(And no mobile coverage at the house, so mini-hubs are a joke for me.)
Message 8 of 16
@p_harris wrote:
No copper to the exchange is available.
(And no mobile coverage at the house.)
How is your phone line working then, as that comes from the exchange not the cabinet? There is no exchange equipment to give dial tone, in the cabinet.
The availability checker says ADSL is available, but upload speed is likely to be very poor.
I think you have got the best connection you are ever going to get, unless Openreach install FTTP.
Message 9 of 16
Quiet line test?
from dslchecker your speeds are better on fibre than on adsl but not by much.  Speeds are within expecked range but you are so far from street cab you are not going to get any better. You appear to be on fibre 2 and would be better on the essential package and save some money
Message 10 of 16
Sorry, meant to say that the quiet line test is... quiet.
