Message 1 of 5
Asus dsl ac68u missing multicast settings
Hi I have recently upgraded my smart hub  to an Asus dsl ac68u and I am trying to set up the IPTV setting to allow me to watch bt sport.
I have done some research and can see that I need to change the multicast settingings, but they seem to be missing from my router web page.
Does anyone know if I need to do something first in order to access these settings?
Thanks in advance
Tags (4)
4 REPLIES 4
Message 2 of 5
Re: Asus dsl ac68u missing multicast settings
@DillanColleer
Firstly I'd update the firmware as that version is out of date, although I don't think that's the reason for the multicast settings being missing.
Did you set up the Asus using the wizard or skip that to do it manually?
I assume that your DSL settings look like mine and you're not using Dual Wan at all:-
Also the Dual Wan page should look like this:-
I'll have  a play with mine to see if any other settings affect the IPTV side of things.
Message 3 of 5
hello Tim,
cheers for the reply
I used the wizard  to set up my router, should I have done it manually ?
my wan internet settings seem the be the same as yours but I am missing PPP MRU setting and I have an automatic DNS.
I am not using dual WAN and my settings look the same as yours on that page
appreciate the help
Message 4 of 5
@DillanColleer
Using the wizard is fine.
Are you on Fibre or ADSL?
And I'd definitely get the firmware updated as yours is 2 years out of date. I'd then do a full reset & start again.
Message 5 of 5
The new firmware fixed it, thought it would ship with relatively new firmware guess I was mistaken.
Cheers guys
