Message 11 of 13
Re: Asus router - data rate is 73% of max rate
Ah - thank you.
How common is it for the sync & maximum speeds to be that far apart?
Cheers, Martin
Message 12 of 13
connection speed and sync speed are normally quite close but with line problems and/or constant resets of router that can cause DLM to reduce connection speed to try and stabilise your line .  if you have line noise then report phone fault to 151
Message 13 of 13
Very unusual except under fault conditions. However, there is something odd with your stats in that with that amount of discrepancy in the figures I would expect your snrm to be very high yet it is 3.1.
