Message 1 of 13
BT 900 slow speed
Hi all,
I had BT 900 broadband installed yesterday and when I run a speed test I'm getting about 90mbps not the 900mbps or 450mbps which is the guaranteed speed. Has anyone else had this problem and know how to fix it? I tried calling the helpline but gave up after 48 minutes on hold!
12 REPLIES 12
Message 2 of 13
Re: BT 900 slow speed
How are you testing your speed, wired or wireless? Which speed test are you using? Fast.com is recommended for an ethernet connection.
Message 3 of 13
Possibly a confusion between megabits and megabytes per second?
Message 4 of 13
@Keith_Beddoe  Possibly that's why I asked how and which test .
Message 5 of 13
Thanks but there's no confusion they advertised and sold me BT 900 the fastest connection in the UK and I'm getting BT 900 the most mediocre connection in the UK. I previous had virgin 100mbsp and it averaged at 110mbps, this connection isn't even close to thoes speeds and is only 10% of what has been promised.
Message 6 of 13
Hi thanks for the quick reply, I'm testing on WIFI using speed test pro. I know a wired connection would be faster but 810mbps faster?? It can't be that different surely.
Message 7 of 13
Hey guys,
Also upload speed is faster than download??
Message 8 of 13
Let us know when you've done a wired test.
Message 9 of 13
Hi, I ran a wired test and got between 600mbps and 940mbps this was using fast.com when I unplugged the ethernet cable and tested WIFI I was getting around 60mbps to 110mbps. Any idea why the WIFI is running so slowly?
Message 10 of 13
Mine went down from 915 mbps to average 350...what’s going on?
