Message 1 of 6
BT Address is Correct but Openreach equipment address is wrong - 10 years and counting
My BT billing address is correct and always has been but my Openreach equipment address is wrong - right house name but wrong postcode. As a consequence whenever I have a fault the engineers go to the wrong address - also I get offers of FTTH when I can really only get FFTC.
I have tried three times over the years to fix it - last time someone said they would "fax" Openreach as that was the only way. Still no joy.
I see other posts where moderators seem able to fix it? Can anyone point me in the right direction?
5 REPLIES 5
Message 2 of 6
Re: BT Address is Correct but Openreach equipment address is wrong - 10 years and counting
Hi @pgbj, welcome back and sorry your address record is not correct with Openreach. We should be able to get this corrected for you. I just need you to check and confirm that the billing address we use is correctly listed with Royal Mail.
Please check and let us know.
cheers
John
Message 3 of 6
Yes. I checked it on the Royal Mail website and it is exactly correct for the postcode.
(MyBt still lists two old accounts I used to have for other properties - the current one is called Cottage, if that helps)
Message 4 of 6
Hi @pgbj, thanks for getting back to us. I've sent you a Private Message so you can get in touch with the Mod team and we'll be happy to help you get the address corrected.
cheers
John
Message 5 of 6
Hi @pgbj, Just to confirm your address record with Openreach has now been corrected.
cheers
John
Message 6 of 6
thanks
