Message 1 of 3
BT Broadband
Hi. I'm after recommendations for products to extend my wifi signal to my shed at the end of the garden. Unfortunately I can not lay cable and the signal will need to reach about 60m plus.
2 REPLIES 2
Message 2 of 3
Re: BT Broadband
Does the shed have a mains supply from the same consumer unit as the house? If not, you are going to struggle to get a reasonable signal at that distance.
Message 3 of 3
Re: BT Broadband
If you have power, it might be worth looking at a point to point system which would then give you an ethernet connection in the shed where you could then connect a wifi Access Point.
Ubiquity do some little dishes that you point at each other to form the link and it acts as if you had run an ethernet cable (if you have line of sight)
