Message 1 of 3
BT broadband internet almost down to 0 Mps
Hi, my broadband internet either wired with ethernet cable or without is down to 0.9 Mbps to 0.03 Mbps this evening since 7:30 pm. How is it possible as we usually have a speed range from 6 Mbps up to 11 Mbps? I rely on this internet connection for my work!!!! Many thanks for your comments, it is HIGHTLY FRUSTRATING and we pay entire £ 24.99 for this service.
2 REPLIES 2
Message 2 of 3
Re: BT broadband internet almost down to 0 Mps
Which version of hub are you using?
Try quiet line test. Dial 17070 option 2 should be silent and best with corded phone
Message 3 of 3
Hi @kimtango and welcome to our community.
Sorry you're having problems with the connection. Did you get this sorted? If not can you please post the details as per @imjolly post and we'll be happy to lend a hand.
Cheers
David
