Message 1 of 32
BT Capping
I have recently upgraded my service on GFast and my download data speed is 140Mb/s but my router stated speed is 388Mb/s, why the difference?
31 REPLIES 31
Message 2 of 32
Re: BT Capping
With them speeds, I would guess you're a F100 customer, if so the speeds are as expected, GFast is still FTTC.
Message 3 of 32
Re: BT Capping
The router speed you're looking at is the max speed you're line will handle. If you're on fibre 100, it's capped at around 145mbps.
Message 4 of 32
Re: BT Capping
I have Fibre 250 with Halo2 and my minimum speed guarantee is 150Mb/s
The router is currently connected with a Data Rate of 328Mb/s but the max download speed I can download from any speed test site including BTs is just under 145Mb/s.
The BT Wholesale test site says my IP profile is 319.2Mb/s.
Message 5 of 32
Re: BT Capping
Ahh ok.. in that case if won't be capped at the download speed you're getting. It's probably the device you're downloading on that hitting it's limits. Even if the WiFi card in the device has a theoretical speed of 350mpbs+, there are other factors that will limit the speed... My wife's laptop had a rubbish WiFi card and wouldn't hit over 8mbps on a 140mbps connection. Stuck a WiFi dongle in with 5ghz and it's up to 38mbps... Nowhere near it's it's max...
Also, if you're downloading from P2P your client could be limited in software or the seeder could be limiting upload speeds which again will limit your downloads...
But if BT say that you're getting XXXmbps, that's what you're getting to the hub. Nothing after that is guaranteed
Message 6 of 32
Re: BT Capping
Also, if you've only upgraded in the last few days it can take a couple of weeks for the line to settle due to DLM
Message 7 of 32
Re: BT Capping
Thanks for the replies. The BT Wholesale test says I should be getting a faster download rate than I am which makes me think that there was a cap for Fibre100 that has not been changed for the Fibre250 upgrade.Test ResultsTest Results
Message 8 of 32
Re: BT Capping
have you tried the test using ethernet
Message 9 of 32
Re: BT Capping
Yes, with the GB ethernet directly plugged into the Home Hub. I can transfer large files on the home network at near GB speeds.
Message 10 of 32
Re: BT Capping
I have the exact same problem! Upgraded to fibre 250 from fibre 100, no change in speeds. They sent me and engineer who showed me the line speeds of 272mb downlpad, I told him that's all well and good but my router is giving me 130/140 max wired.
So they send me another router, no difference. Now they're sending me discs as they say that will pickup my wired speed which I know it won't 😕 seen a few posts now like this, bt have a problem
