Message 21 of 22
Re: BT Cloud Update Dec 2020
My only issue now is what to do about BT Cloud - just leave it until the next upgrade? or should i delete it?
Anonymous
Not applicable
Message 22 of 22
@Iank2
You're welcome and thanks for letting me know that all is good.
If I were you I would leave the BT Cloud app off for now, after all that's you put in the position you found yourself in. I'm sure you'll find out on this forum when they fix the problem
You can always browse to it if you need access to your files, I think the address is btcloud.bt.com but Google will find it if I'm wrong
