Message 1 of 3
BT Fibre 900 Upgrade / Smart Hub 2 upload throttling
Hi team.
This is my first post here and I am hoping that somebody may be able to help me.
My firmware was updated on the 24/09/20 and now my upload speed has dropped. Before the upgrade I was getting 920mb down and 120mb up I am now getting 920mb down but only 50mb up when using the Smart Hub 2. If I connect a netgear router I can get 920mb down and 120mb up.
2 REPLIES 2
Message 2 of 3
Re: BT Fibre 900 Upgrade / Smart Hub 2 upload throttling
Message 3 of 3
@fatsnow
Hi mate, BT do not throttle any packages and have it in their terms to read.
https://www.bt.com/help/broadband/bt-s-approach-to-broadband-traffic-management
The upload problem you are experiencing is quite common among the 910 / 110 package users and is confirmed it's the supplied Smart Hub 2 that is the problem.
You need to contact a Moderator on this forum to "Hopefully" get a fix until BT release a newer version of their hub with a permanent fix.
Alternately do as others have done to get a permanent fix and purchase a quality router (WiFi 6 enabled) and make use of the package you are paying for.
I know users shouldn't have to buy their own router but its a 100% fix.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
