Message 11 of 18
Re: BT Fibre 900
Tom I presume they removed your original copper and telephone socket the way you are talking.
On my install they left the original copper service including telephone socket so no issues still using the house phone.
When the time comes (2025 I heard) I will probably do away with the house phone permanently as both me and my wife use our mobiles for all calls now.
___________________________________________________________________________________________
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 12 of 18
Re: BT Fibre 900
What third party router do you use?
Message 13 of 18
Re: BT Fibre 900
Honor Router 3
Message 14 of 18
Re: BT Fibre 900
Yes We originally had phone line through copper but it was years ago since it was active. We only used mobiles  until they offered it as part of package with fttp. Didn’t release that it was wireless thought they still connected it to copper lol.      So I bet now when I switch off the SH2 hub signal the black discs and voice service will stop working as it uses the Wi-Fi signal from it to work.  So the Wi-Fi 6 router is kinda pointless
Message 15 of 18
Re: BT Fibre 900
Phone should still work with wireless turned off as the hub is a dect base station.
Message 16 of 18
Re: BT Fibre 900
ok not sure if  the BT Black mesh disc will work then though when the wireless is turned off?
Message 17 of 18
Re: BT Fibre 900
In add to the iPhone 11 Pro Max internet speed you had with the router how did you achieve those speed my last quickest speed test here from 12 Pro which is 2X2 Wi-Fi only.
Message 18 of 18
Re: BT Fibre 900
I don't think it best to have two routers connected, going to stick with third party router. I think there is a way of porting that number to another provider and then connecting to the third party router?
