Message 1 of 3
BT Fibre FTTC - random drop outs
Hi everyone, I'm on FTTC with a SmartHub.  Generally all is well and my BB is reliable and consistent at
10.00 Mbps / 55.00 Mbps.  I work from home so obviously notice drop outs more which causes the Smart Hub to resync.  I was just wondering if there is anything obvious from the my line stats that might explain this, I have no clue!
I've tested my line with the silence test and that seems OK.  Sometimes I can go 10 days plus (never more than 14) without a dropout.  Other times the Smarthub resyncs once a day for for 2-3 days.  I've generally noticed drop outs occur either in the evening 6-9 or early hours.  Really appreciate any insights.
Product name:
BT Hub 6A
Firmware version:
SG4B1000E020
Firmware updated:
20-Dec-2020
Board version:
1.0
Gui version:
1.115.0
Data rate:
Maximum data rate:
13729 / 64255
Noise margin:
8.2 dB / 5.5 dB
Line attenuation:
38.6 dB
Signal attenuation:
24.9 dB / 38.6 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
2 REPLIES 2
Message 2 of 3
Re: BT Fibre FTTC - random drop outs
From dslchecker results you had 63/13 mb connection on 29/10 but you now have 55/10mb suggesting you were on fibre 2 but have now downgraded to fibre 1 maybe to save money. Did  you make the change or is there an error.
Stats don't show connection time.
Did you try using test socket with a filter to see if that helps stability
Was quiet line test absolutely silent?
Message 3 of 3
Hi, thanks for the reply. I've always been fibre 1, never got above 55mb so that sounds like an error! Line test not absolute quiet but I'm using a cordless phone so heard what sounded like a normal low, dull hum sound (no cordless I'm afraid).
I tested once for a couple of days with the test socket and filter, had one drop out in that time so on a par with now.
