Message 11 of 23
Re: BT Full Fibre Upload Capped
@PaddyB
my internet restarted today and for some reason my hub has now put me back to only 50upload instead of a 110, soon as I plug my own hub in its back to 110, can you please sort this out for me as I need to use the SH2 for the digital voice
Message 12 of 23
Hi @Steveyk98
Thanks for your post and welcome back!
I'm sorry for the problems you're having with your upload speed.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
Message 13 of 23
@RobbieMac yes mate I’ve replied with the details
Message 14 of 23
Hi @Steveyk98 ,
Thanks for the reply. I can see your email in our queue. One of the mods will be in touch soon.
Cheers
David
Message 15 of 23
okay Thankyou, is this a common problem with the full fibre 900 package and is it an easy fix or? @DavidM
Message 16 of 23
Hi @Steveyk98 ,
We've seen a few of these but I'll need to take a look to check what the issue might be.
Cheers
David
Message 17 of 23
I got a shocker news today from BT CS staff (Jass) if it's her real name - because the way she come across was very rude!  She basically told me categorically that even I signed up for Full Fibre 900 Halo 3, BT can never deliver that, she said the maximum I can get is 600 download capped! and I repeat she said it's capped! so the 700 stay fast guarantee is just marketing strategy, though I know she doesn't have a clue what she was talking about as some of her words contradicts itself. When I asked her capped by what? she replied by device, and what device?, she said Laptop! Has anyone been experiencing similar issue?. I was shocked, even talking to her as a customer service for BT degrade the value for BT as a company. Broadband speed capped by device, your laptop - BT customer service agent??? I'm looking into buying this router - ASUS RT-AX58U WIFI 6 AX3000 Dual-Band Mesh WiFi System Router any advise?
Message 18 of 23
ASUS RT-AX58U WIFI 6 AX3000 Dual-Band Mesh WiFi System Router any advise on connectivity/setup
"Can I use this for BT  Full Fibre and how can I connect it, stand alone directly to the socket or with BT router as a modem? can someone please help"
Though not sure if this is the right thing to do since BT has capped my speed to 600 as advised by BT staff
Message 19 of 23
For full fibre you don't need to use the BT hub unless you want their digital voice telephon service.
You can use the Asus router on it's own, just plug it onto the ONT which will be fitted for full fibre and set it up for a PPPoE service.
Username [email protected]
Password BT
VLANID 101
BTW ther BT adviser didn't know what she was talking about, you will get the full 900Mb, there is no 600Mb cap.
Message 20 of 23
Thanks for the reply.. I have just reply to your comment on another thread very informative.. thanks for the contribution
BT FTTP 900/110 installed yesterday..... - BT Community
Can you image she even told me it's the problem with my laptop network card, my laptop?? can't believe it. I have raised a complaint with BT
