Message 1 of 22
BT Hub Event Log
I have recently had my wifi hacked with serious intrusion into my personal life. I ended up changing the hub password and re-setting all my devices with the new 12 character password. I still feel this may be happening again. I found the hub event log which shows activity from 00.02 to 01.46 on the 14th June when none of my devices were being used.
My first login was at 06.19 as recorded on log.
Can anyone shed any light on this for me? \thanks in advance. See attached screen shot of log event.
Event log 14th June 2021Event log 14th June 2021
21 REPLIES 21
Message 2 of 22
Re: BT Hub Event Log
the TR69 entries are the BT update server checking hub for updates - if that is the 'hack' you are worried about
Message 3 of 22
Thanks for your reply. I'm not familiar with hub event logs at the moment. If TR69 is BT owned then that's good news.
Thanks again.
Message 4 of 22
Re-starting Hub?
Is it good practice to re-start the hub after changing password?
Message 5 of 22
Re: Re-starting Hub?
No
Message 6 of 22
no need to restart
Message 7 of 22
Thanks.
Message 8 of 22
Thanks.
Message 9 of 22
copy and paste password
Is there a way I can paste my admin password in the dialogue box when changing password. I have to do this manually and it does recognize the password?
When using initial login for admin It will let me paste it in successfully?
Your help would be greatly appreciated. PS BTHub6
Message 10 of 22
Re: copy and paste password
Why do you keep changing the admin password?
