Message 1 of 6
BT MOBILE NETWORK dropping?
Hi my BT network keeps dropping from my mobile so I have to go to setting to reselect it to get it registered on the BT network.  I have swapped phones recently and never had to do this with the old phone. Any ideas how to get the BT network properly linked to the phone? It's a Samsung 20+ 5G. Thanks
5 REPLIES 5
Message 2 of 6
Re: BT MOBILE NETWORK dropping?
did you update APN in network settings to BT Mobile
Message 3 of 6
No...how do I do that for BT? Do I need a special APN code or name? Thank you for replying! If I open APN there is a whole list of names....
Message 4 of 6
this should help
https://apn-settings.com/uk/bt-mobile-apn-settings/
Message 5 of 6
Thanks....I will try this....it is actually happening to my partner's phone too so may be a wider problem....really grateful for your replies.
Message 6 of 6
One always has to set new phones up. More an updating requirement rather than a problem.
