Message 1 of 8
BT Pro Box Picture issue
Having this issue when turning Box &  TV on. Picture zoomed and in one corner.  TV Samsung 40" MU6400
It goes OK if I change source to "Live TV" and then back.
7 REPLIES 7
Message 2 of 8
Re: BT Pro Box Picture issue
Hi, @gibbylinks Thanks for posting, have you tried connecting to a different HDMI port on your TV?
Neil
Message 3 of 8
Apologies for slow response, but ironically it's not done it since.
Message 4 of 8
Hi @gibbylinks, thanks for the update and hopefully it won't happen again. If it does occur again do pop back and let us know.
cheers
John
Message 5 of 8
It's back to doing this. Only does it every so often and I've tried swapping HDMI ports.
Any ideas?  Caused the wife to inadvertantly make BT Store purchase this morning lol, which baffles me as I thought it was PIN protected. 😂
Have to check when get home..
Message 6 of 8
I'm still have this issue.
Message 7 of 8
Hi @gibbylinks
Thank you for posting back.  Strange issue!
Sorry this is happening.  Can you try a different HDMI cable to see if that resolves it please?
Thanks,
Robbie
Message 8 of 8
OK, swapped cable over. Although the original HDMI cable was the same as I was using on my previous 4K Humax BT box prior to swapping over to the Pro box.
I'm also experiencing picture and sound dropouts. Screen goes blank for 5-10 seconds before picture returns.  Think that has been posted elsewhere on here, but without resolution.
Never had either of these issues with the old box.
