Message 1 of 7
BT Smart Hub 2
I had FTTP installed on Monday 13th July (Fibre 250 with Halo 1).
2 Problems (Faults):
  1. The Smart Hub 2 (Ser No: +091300+2011000892) provided by BT will not save any changes to the advanced settings.
  2. Upload speeds on Ethernet connection are very slow (c.8Mbps). (on WiFi upload speed is OK (c.50Mbps).
6 REPLIES 6
Message 2 of 7
Re: BT Smart Hub 2
Give the FTTP team a ring, they'll most likely send a new hub out. 0800 587 4787
Message 3 of 7
Re: BT Smart Hub 2
Thanks. Will try that approach.
Message 4 of 7
Re: BT Smart Hub 2
In the meantime, make sure nothing is plugged into LAN port 2 on the hub. Try your speeds again using ports 3 or 4.
Cheers
Ted
Message 5 of 7
Re: BT Smart Hub 2
What’s wrong with lan port 2?
Message 6 of 7
Re: BT Smart Hub 2
I've had two SH2's now and both dropped LAN port 2 down to 10mbit when using more than one 1gbit connections.
I don't think these hubs can handle multiple 1gbit connections!
Cheers
Ted
Message 7 of 7
Re: BT Smart Hub 2
Thanks Ted
