Message 1 of 3
BT Smart Hub 2
Hi I have recently moved into a new build property, I have my new smart hub 2 router and a phone line, just need connected from local exchange. My question is can the hub connect to BT WiFi hotspots and act as a hotspot for the house? Running through data like crazy as my engineer is booked for weeks down the line
2 REPLIES 2
Message 2 of 3
Re: BT Smart Hub 2
you need you home connected to the internet before conecting hub and able to use BTWIFI
if you are a BT CUSTOMER then you can connect to BTWIFI if there is a signal from a neighbour
Message 3 of 3
Re: BT Smart Hub 2
The hub itself can't connect to BTwifi and be used as a hotspot, only your devices can connect.
